Getting really bad curling on overhangs - Curling did not appear during a test print
Pagina 3 / 3
F0erster
(@f0erster)
maybe a little more base
you might not need the complete model but just a little more base to get some lateral stiffness in there. These posts are probably moving a bit when the nozzle travels over the edges...
@swiss_cheese
how would you counter or customize in the slicer for such a model and pla? i don't know what to change since my temp-tower and speed tests were underwhelming and they seem to be the most influential parameters to change for bridges?
Postato : 22/09/2021 8:37 am
Swiss_Cheese
(@swiss_cheese)
Hopefully Helpful Hints
The bridging on this model is easy peasy for a prusa printer, in fact bridging is not the problem here at all. The problem's here are Infill, Heat  and the amount of overhang the few layers before the bridged areas have. this is a small model, the features are smaller yet, a little bit of heat goes a long way, and tiny adjustments to perimeters in the problem areas can make all the difference. sometimes this can be an adjustment to the perimeter widths or a layer height or both, sometimes if we add a perimeter it will remove potentially troublesome infill. it's these tiny things that make a difference to these tiny features.
Beer_Crate_Hints_Swiss.Zip
Good Luck, Have fun.
Swiss_Cheese
The Filament Whisperer
Postato : 22/09/2021 8:59 am
_FirstLayer e ssill2 hanno apprezzato
ssill2
(@ssill2)
correct
I let this go enough to watch it hit the bridge.  you are 100% correct here.  the edges start curling up a couple layers before.  By the time it hits the layer where bridge happens, the nozzle is in fact hitting the model.   I'll give your print a try.  I'm quite sure it will be an improvement, you are the filament whisperer after all 🙂
Here is 2.3.3 slice of FOerster's .3mf
Posted by: @swiss_cheese
Swiss_Cheese
Postato : 22/09/2021 10:42 am
ssill2
(@ssill2)
swiss you've done it again
Not surprising, but kudos to you for being the filament whisperer 🙂
Postato : 22/09/2021 2:17 pm
ssill2
(@ssill2)
final result
About as good as I think could be expected without putting some supports in there.
Way to go swiss
Postato : 22/09/2021 2:54 pm
Swiss_Cheese hanno apprezzato
Swiss_Cheese
(@swiss_cheese)
Nice print ssill2 I like that color also 👍
These were the results from the .3mf I posted with the adjustments I mentioned previously.
Regards
Swiss_Cheese
Postato : 22/09/2021 4:11 pm
F0erster
(@f0erster)
are you a magician?
Not at home for the next days so unfortunately I cannot try your settings right now… but insanely good results, I wonder what your adjustments are?
And where did you learn these dark arts?
Postato : 22/09/2021 5:38 pm
ssill2
(@ssill2)
the dark side of the force
Is strong with him 😉
He finds clever ways to make the PrusaSlicer his b*tch lol
Posted by: @f0erster
Postato : 22/09/2021 5:43 pm
Swiss_Cheese
(@swiss_cheese)
That's hilarious, I'm going to take that and set it right here next to my RED NinjaFlex BitchSlap profile.
Regards
Swiss_Pimp
Postato : 22/09/2021 10:27 pm
ssill2
(@ssill2)
as always
Glad you approve 🙂
Regards
Swiss_Pimp
Postato : 22/09/2021 10:29 pm
Unlimitedbass
(@unlimitedbass)
RE: Getting really bad curling on overhangs - Curling did not appear during a test print
Hi Swiss_Cheese,
i have nearly the same issues at some prints. What is your magic trick for such perfect overhangs?
The zip isn't available anymore 🙁
Regards
Unlimitedbass
Postato : 07/02/2022 11:08 pm
_FirstLayer
(@_firstlayer)
@swiss_cheese: I'm having a similar problem and I wanted to learn from your adjustments. Sadly, your zip isn't available anymore 😫 . Could you repost it, or do you have another way of sharing your knowledge?
Kind regards,
First_Layer
Postato : 05/03/2022 5:29 pm
MalsBrownCoat
(@malsbrowncoat)
Necro'ing an older thread, but curious of either Swiss_Cheese, ssill2 or anyone else would be willing to reshare the zip file that was posted, but now leads to a dead link?
There are several of us here that would be interested in hearing more about the methodologies used for these results.  Thanks!
Postato : 29/07/2022 9:05 pm
Swiss_Cheese
(@swiss_cheese)
To everyone:
Prusa has this very nasty habit of deleting project files and images from posts without warning, if you ask me it's a real shitty thing to do, and I know some others who agree. That's what happened here.
As I help here, in as much as my time will allow, I normally don't save all the project files after I post them (and there are quite a few). In this case however I do have the original project file. But it won't really do you much good because it was created in 2.3.2 after this version Prusa decided to make some file breaking changes, in general I would agree the changes where for the better. To make a long story short and at its most basic, they flipped the hierarchy of the stack in the "Object" & "Parts" menu. So if you try to use the 2.3.2 Project file it wouldn't print correctly.
Okay so all that said we can still make this happen. I had unsubscribed from this thread and wasn't seeing the reply's, I stumbled upon them. I am willing to remake this file, I had in fact redesigned the Create to be stackable for my own use, and then Tuned it.
So what I'll do if your still interested is rebuild the file for 2.4.X and up and re-post it here with some explanation.
Keep in mind you can't count on Prusa to leave the files alone, if you think your going to want to view this again save the files and page as a whole for future reference. I actually purchased a web domain to save all these tutorials to but there was so little interest expressed I decided not to use it.
Ill get back to you.
Regards
Swiss_Cheese
Questo post è stato modificato 2 years fa 2 tempo da Swiss_Cheese
Postato : 29/07/2022 11:49 pm
_FirstLayer
(@_firstlayer)
Hi @Swiss_Cheese,
I'm definitely interested! I have learned a lot from your other posts. Reading the op's initial post and your answers to that, then analysing what you did and especially why you did what you did, is incredibly educational for me. I can really learn so much from you!
Thank you so much!
_FirstLayer
Postato : 03/08/2022 3:45 pm
Swiss_Cheese
(@swiss_cheese)
@_firstlayer
I'm going to try and work on it this weekend. It's been a busy week. I'm actually looking forward to being able to sit & focus on it.
Regards
Swiss_Cheese
Questo post è stato modificato 2 years fa da Swiss_Cheese
Postato : 03/08/2022 9:58 pm
_FirstLayer hanno apprezzato
_FirstLayer
(@_firstlayer)
@Swiss_Cheese,
Thanks! Take your time, no need to rush! I have a busy week coming myself 😉 .
Your willingness to teach, is so appreciated! Thanks!
Kind regards,
_FirstLayer
Postato : 04/08/2022 8:06 am
Pagina 3 / 3
