Gaps in walls
Good evening,
Is it an under-extrusion issue ? I print an empty test cube with 0.65mm walls thickness and I measured 0.65mm on average on every wall. I supposed my extrusion should be fine ?
Thanks for help !
Postato : 22/02/2020 8:41 pm
Postato : 22/02/2020 8:46 pm
RE: Gaps in walls
Slipping gear on extruder motor?
Postato : 24/02/2020 8:31 am
