For Swiss
For Swiss
@swiss_cheese
Here's one for your perimeter controlled anti-bulge method Swiss - any ideas?
Bulging occurs along the vertical joins - but is not consistent; half the object shows no artifacts, then in the middle of the upper half a section shows artifacts, and there are even a few spots the artifacts show but are not adjacent to the internal variations. What has me stumped in the extrusion width appears to be unchanging.
SegNum1
Veröffentlicht : 30/05/2021 4:23 pm
Swiss_Cheese
(@swiss_cheese)
RE: For Swiss
LOL! 🤣
OK, now that that is out of the way,  🤨
I ran this print, but I stripped out most of the settings you had in the .3mf changed them to my own and got a reasonable result.
I had no discernible issues, in fact aside from the wobble (expected) that occurred from the upper middle on (because I used no supports) I didn't have any problems.
So I switched up to silk PLA and printed, (same wobble) no supports and you can Baaarrrley make out the area that your talking about, it is lined up with the internal seam of the perimeter wall. you can't feel it at all, it doesn't exist as a bump, only a difference in reflected light. I even had trouble getting a picture of it, but I tried
I'm going to run one more and see if I can't get it to disappear.
Regards
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 30/05/2021 10:49 pm
ssill2
(@ssill2)
RE: For Swiss
@swiss_cheese
The filament whisperer is a title you every bit deserve! 🙂
Veröffentlicht : 31/05/2021 1:22 pm
Swiss_Cheese
(@swiss_cheese)
RE: For Swiss
Thank you kind Sir  😀
Veröffentlicht : 31/05/2021 4:41 pm
RE: For Swiss
Here's the bulge ... the central right one ... it starts and stops abruptly where the top infill changes. Just above the hub to the top 1/4 inch.  My guess is it's something to do with LA and direction of infill travel.  But this overall effect is something new - it isn't the typical perimeter issue.
And an oddity to this is there is no such artifact below the hub, yet the part is identical ... lol.
ps: the wobble was expected; and exists even with minor support. The part needs a bit more bulk attaching perpendicular to the hub.
Diese r Beitrag wurde geändert Vor 4 years 2 mal von --
Veröffentlicht : 31/05/2021 5:08 pm
Swiss_Cheese
(@swiss_cheese)
RE: For Swiss
@Tim
This is the cause of your blemish.
On my version of the .3mf this change occurs at 95.20mm Layer 476.
Prior to that, the seam for the internal duct is Here.
It should be possible to change the seam position back, or even to change the shape
in your 3D program of choice to have it be in the center interior.
I've not tried that on this model yet, but I do plan to.
I did design a support for the wobble and that worked better then expected but still needs minor adjustments.
I think that time spent on changing the internal seam will be better spent to correct the problem.
I have printed this twice now, and it's barley perceptible, but I can see it.
this is the support, it currently uses 14.82 g of filament but was designed in haste to accommodate the need.
I changed quite a few things in the originally posted .3mf
You may be interested to know I changed the perimeters & external perimeters to 0.47
I plan to pass along the .3mf after I get it perfect, it's a very busy time for me right now, but I'm happy to help.
Don't disappear, you do good things here.
Regards
Swiss_Cheese
Veröffentlicht : 31/05/2021 6:19 pm
ssill2
(@ssill2)
RE: For Swiss
@swiss_cheese
Nice!   Showing again that your moniker is well deserved lol
Veröffentlicht : 31/05/2021 6:23 pm
