Flexfill 98A - no good extrusion
Bort
 Bort
(@bort)
Hello 3d printing folks!
I am struggeling with this ugly flexfill 98A, but it fits my solution best.
It is very hard to explain: I preheat the printer and then run the extruder motor to run out some flexfill. And it comes out, not like a straight line, but thick and thin, in very short distances between thick and thin. If I move it between my fingers it feels rough.
It is the same when printing a modell. The modell has no smooth surface and is not very robust.
It can not be the settings as I also have it in manual mode. And even got some good models out. I also cleaned the extruder with ABS-T, which didn't have this.
Do you have any suggestions what can be the issue?
Veröffentlicht : 24/05/2020 7:35 pm
Bort
 Bort
(@bort)
RE: Flexfill 98A - no good extrusion
Here is some picture of the result and one of the string, where you can a little see the roughness of it.Here is some picture of the result and one of the string, where you can see the roughness of it.
Veröffentlicht : 24/05/2020 8:38 pm
@schlager-rupert
Could your filament be damp?
Joan
Veröffentlicht : 25/05/2020 12:34 am
Bort
 Bort
(@bort)
I hoped for another answer, but seems like I needed to waste one role of filament to learn this.
I took of 20 meters of it, but still have the issue.
How likely is the chance that I can dry it with normal household equipment? Or better just to buy a new role?
I found this page about that topic:
https://fillamentum.com/pages/drying-filaments-before-processing
I want to give it a try unless you don't tell me that it is not possible at home.
Veröffentlicht : 25/05/2020 1:14 pm
If you have an electric domestic oven that can reliably run at low temperatures, you can try heating the roll in the oven for several hours at 55C
if you have a humidity meter, you can try putting that in the oven to monitor the oven humidity... 🙂
https://www.printdry.com/how-to-dry-filaments/
DO not use a GAS oven,
two reasons..
Gas ovens tent to cycle Hot /cool Hot/Cool...     and melt your filament  and probably the reel at the hot points......
And Gas Combustion causes water as a by product.
not a good mix, for drying filament
Veröffentlicht : 25/05/2020 11:51 pm
I put a sacrificial roll end in my oven to test the meltability factor, with a temperature / hygrometer...  While I watched, it was OK, and after a couple of hours the roll was still roll shaped, with filament still on it... not a blob of PLA,,,,  🙂
I have a sheet of teflon in the bottom of the oven and put a metal tray under my reel, Just  in case...   Mine is a fan assist oven
Joan
Veröffentlicht : 25/05/2020 11:56 pm
Bort
 Bort
(@bort)
Thank u!
I have a brand new electric oven with 4D Hotair-ventilated... don't know the english term exactly, but best fries ever!!!
I put only somewhat 10 m inside on an empty spool and used the 100°C, from my link above.
Perfect printing now!!! Thank you @joantabb for your help!
Veröffentlicht : 28/05/2020 2:08 pm
