FLEX filament TPE32 object shrinking
Hello,
When printing simple thin tyre from TPE32 flexible filament, the printed tyre is shrinked little bit within first approx 10mm from the bed:
I'm using PM Filament TPE32 and their original print profile: https://www.filament-pm.cz/tpe-32-rubberjet-flex-cerna-1-75-mm-0-5-kg/p90?fileId=1969&do=downloadFile
Printed on PP office tape with non heated bed.
Sliced model contains inner brim, seam is random:
I've tried to print tyre with printer enclosure cosed to keep the surroundings warm and also the opposite situation with printer on well ventilated space, but the result was almost the same.
Do you have any idea, what do I do wrong?
Thank you!
Posted : 27/12/2024 7:58 pm
