First Layer not uniform
Andrew
(@andrew-21)
Typically my first layer is what fails if a print fails
I've run the first layer called, and adjusted the live Z, but the right side of my bed is always super thin (causing the extruder to knock)
Any further suggestions? The bed is clean and there are no pieces of debris
Veröffentlicht : 28/05/2018 6:36 am
Re: First Layer not uniform
first of all, run the Z axis up to the top and let the motors stall,,, to ensure that the X axis is level.
if the problem persists,
there is a Bed level Correction option in the calibration menu,
you can adjust left, right, back and front, relative to the middle,
you could try positive values on the right and negative values on the
or you could try ultra fine bed levelling... but that's more technical
Veröffentlicht : 28/05/2018 11:31 am
turfsk8r
(@turfsk8r)
Hi Joan.
I remember reading the post about ultra fine bed leveling but can't seem to find it. If you have the link for that thread handy I would greatly appreciate it.
Thanks,
chad.
Veröffentlicht : 04/11/2018 5:35 pm
turfsk8r
(@turfsk8r)
Hi Joan,
I found what I was remembering reading. Is this what you were referring to?
https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f78/hyperfine-bed-leveling--t4330-s400.html
Chad
Veröffentlicht : 07/11/2018 7:16 am
