First layer cal is golden, first layer of prints are intermittently trash
[Gelöst] First layer cal is golden, first layer of prints are intermittently trash
0x90
 0x90
(@0x90)
The title I think says it all - my first layer cal is solid at -1.475. Going down to -1.5 leaves me with roughness (as if its trying to pull up).
When I print my first layer of something, in this case, a small part with round holes using .15 layer height, sliced for PLA (and using Prusament PLA) using PrusaSlicer 2.3.3 I wind up with a first layer that looks like the following attached photos. The rest of the print turns out fine, and adhesion isn't an issue.
Any thoughts on what I might do to troubleshoot this issue? This seems to come and go, maybe. I printed a project box the other day and the first layer of that was fine. Todays prints seemingly have gotten progressively worse
Best Answer by sylviatrilling:
This link explains another way to calibrate your z-offset that might give you better results. https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
Also, make sure there is no debris between your removable sheet and the magnetic bed. And try switching you bed leveling from default 3x3 to 7x7.
Veröffentlicht : 03/10/2021 8:53 pm
sylviatrilling
(@sylviatrilling)
Try this
Mk3S+,SL1S
Veröffentlicht : 03/10/2021 9:30 pm
0x90
 0x90
(@0x90)
Thank you!
Thank you so much for this link - this is absolutely a superior first layer cal! Issue appears to be resolved now!
Veröffentlicht : 03/10/2021 11:12 pm
sylviatrilling gefällt das
