Figure impossible to print!
Nessuno0505
(@nessuno0505)
https://www.thingiverse.com/thing:1168292
Santa Claus in particular:
It is printed sitting and it suggests to print without supports, but the beard always slides forward after a while! It is attached to the bed only through its tiny bottom part, and all the beard grow backwards, and after a while it detaches from the bed sliding forward. The rest of the figure sticks normally to the bed. Did someone print it? How? Thank you.
Postato : 29/10/2018 2:48 am
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: Figure impossible to print!
Try about a 5 to 10 mm brim
Postato : 29/10/2018 5:39 am
Nessuno0505
(@nessuno0505)
Is It possible to put a brim under the beard only? Since foldable legs lie under the bottom and I'd prefer not to stick them with a brim. In other words: is there a way to put custom support structures instead of slic3r automatically generated ones? Or to customize / modify the brim once generated?
Postato : 29/10/2018 10:13 am
Nessuno0505
(@nessuno0505)
Tried to modify the stl just for the beard, but also the arms are a weak point.
A 5 mm brim was the best solution: perfect print and not so hard to remove at the end.
Thank you for the help. 😉
Postato : 30/10/2018 9:48 am
