Fan shroud how to print
viehhausen5
(@viehhausen5)
Hallo
may be stupid question... but I broke my fan shroud after some 1000 hours while changing hot end. Not I downloaded this file
https://www.printables.com/de/model/88272-i3-mk3s-printable-parts/files#preview
Can I print it laying on the bed without support / filling from underneath ? Unfortunately inly stl and no infos are at the page and any help welcome. I cant imagein how to print the middle bridge without support
thanks for any help. I have other problems after hot end change (org Prusa) but that is first one
the arrow shows my critical area ...
thanks
Benno
Napsal : 14/10/2022 7:04 pm
Yes, print it as-is, it contains a predefined support that you break out before fitting.
Napsal : 14/10/2022 9:06 pm
viehhausen5
(@viehhausen5)
RE: Fan shroud how to print
Hi
got it running! It broke out itself… now my Prusa is running with new hot end again.. 6000 hours in 2 1/4 years … what a great machine!
Napsal : 14/10/2022 9:13 pm
1 lidem se líbí
jsw
 jsw
(@jsw)
I recommend that you print this at minimum with ABS/ASA, and preferably with something higher temperature, like PC Blend.
The original on mine (I assume ABS) started to droop after a fairly long run of ABS prints, and I found a remixed one (below, left) that looked a bit more sturdy.
I printed both the remixed one and the original (right, below) with PC Blend and made the decision in real time to use the remixed one when I had the machine down for repair.  It has not drooped since.
Napsal : 14/10/2022 9:36 pm
