Extruding "late start"
I will appreciate if you can give me some advice about this problem:
There is an incomplete extrusion in the upper portion in the union two cylinders (please see the figures).
I don't know the direction of the header with this happens, so I'm not sure if it is under extruding or what.
Printed with an i3 MK3, at 0.25 layer high, 0.4 nozzle
Sliced with Slic3r 1.41.0+, linear advance for the filament is the standard (K=30)
Perimeters speed: 120 mm/s
Retraction:0.8 mm, speed: 35 mm/s, min travel after retraction: 1 mm
PLA from Markergeeks (US based).
How can I fix it? I have to print several of these pieces, and each takes about 11 hours, so testing is time consuming.
Thanks in advance!
Respondido : 06/11/2018 7:47 pm
