Eliminating stringy's
mbuto
(@mbuto)
Howdy all,
1st attempt at this knob gave me all the stringy's.  What can I do to eliminate them?
Thanks,
Mike
Publié : 10/09/2020 6:07 pm
jsw
 jsw
(@jsw)
RE: Eliminating stringy's
Lots of things can cause stringing.  Everything from wet filament to improper retraction to non-optimal nozzle temperature to speed.
Yours does not look too bad.  A quick swipe with a low-temperature heat gun should get rid of those quickly.
You might print one of those temperature towers with the same filament to see the temperature that works best with it.
Publié : 10/09/2020 6:15 pm
1 personnes ont aimé
In my experience, the biggest contributors to stringing are:
  1. Absorption of moisture by filament over time (remedied by drying).
  2. Over-extrusion (remedied by calibrating your extrusion multiplier for each filament).
As @jsw notes, other factors such as heat can figure into it as well, though once I've calibrated everything, my temp towers end up looking mostly uniform.
I've compiled some notes on how I've gotten stringing mostly under control here that you might find useful.
Publié : 10/09/2020 6:59 pm
Swiss_Cheese
(@swiss_cheese)
You didn't mention what kind of filament you used, and it matters for a more accurate answer. However, Bobstro & jsw have thrown some very good information your way, and I would like to add one more bit to it, In Print Setting, Layers and perimeters, Quality. Tick the little box that says (Avoid crossing  perimeters). It has the  potential to greatly reduce the amount of stringing.
Good luck
The Filament Whisperer
Publié : 11/09/2020 2:16 am
Good point. Disabling z-lift can help as a quick fix as well, though I'd recommend eliminating the need for it (by calibrating your extrusion multiplier) eventually.
Publié : 11/09/2020 4:12 am
mbuto
(@mbuto)
This was the stock Prusa filament that shipped with my printer
Publié : 11/09/2020 6:25 pm
Talaminator
(@andrea-t)
I had a similar experience in the past printing a very similar object, and why my solution might not properly solve the cause of the problem you will at least get rid of strings on that particular object...
i can imagine that your external layers are laying down well and clean but then the nozzle come back for the "gap fill" between all those pointy edges of your model, leaving strings...
in my case worked out wonderfully turning off gap-fill completely, the object was more than strong enough anyway and at this point without any strings! and well, it printed faster...
Publié : 14/09/2020 7:40 pm
semprul
(@semprul)
At first I also had the same problem. I tried this (Temperature & Bridging Tower)  design and finally found a suitable temperature for each filament I had.
Thank you @bobstro for the explanation.
To have or to be?
Publié : 15/09/2020 1:24 am
