Disappearing edges from Part after slicing
Mohammed lamine Mekhalfia
(@mohammed-lamine-mekhalfia)
Hello Prusa users.
I am facing a problem concerning the printing of a part. When I slice, some of the part element disappear, I tried to google the issue I found that it is common somehow but even though I followed the suggestions I couldn't resolve it. Any one has an idea or could help me? Attached an overview of the problem.
This is the link for the Stl file :
https://drive.google.com/file/d/1Oplgg_yNe9NB_YhalZajmJhMNWTJqSJs/view?usp=sharing
Opublikowany : 26/05/2023 2:27 pm
That's a difficult part to print, it needs rotating to fit the bed and then the orientation of the lay remains problematic.  Without some engineering insight the stress lines are hard to estimate.
The part is very thin with knife edges, never easy to print and prone to varying errors depending on slight changes of rotation - also it requires very complex supports.
I presume it was not originally designed for FDM printing.
Files > Save Project as
Opublikowany : 26/05/2023 10:20 pm
