different temperatures in different models
AR
 AR
(@ar)
I'd like to print multiple objects in a sequential print job. Each object requires different filament temperatures on certain hights. The hights are varying from object to object.
At first I solved the problem with different temperatures by a custom G-code "Before layer change G-code".
;BEFORE_LAYER_CHANGEG92 E0.0;[layer_z]
"VAR TEMP"{if layer_z > 135.85}M104 S[temperature]M221 S100
{elsif layer_z > 3.05}M104 S[first_layer_temperature]M221 S{extrusion_multiplier[0] * 100}
{elsif layer_z > 0}M104 S[temperature]M221 S100
{endif}
But when it comes to different temperature zones in different objects, this obviously doesn't work any more.
Is there a way to deffine the print temperature by modifyers?
In the end, I'm looking for a practical solution for batch prosessing. The modifyer geometry can be created easily.
I'd be glad, if you could help me.
all the best,
Rupert
Postato : 15/04/2023 4:00 pm
