Cura "Make Overhangs Printable"
Hi All!
I use cura with my ender 3 and I am able to toggle a function and set and angle for the "make overhangs printable" feature of cura, which basically adjusts your mesh so that the angle will not cause blobs under overhangs and such.
This is a great feature of cura, how can I replicate the same functionality in prusaslicer?
I tried the print on my mk3s at .2lh and it turned out terrible!
Posted : 06/02/2020 11:56 am
RE: Cura "Make Overhangs Printable"
Use Cura with your MK3S if you are happy with it. The forum has Cura profiles for Prusa.
Posted : 06/02/2020 5:51 pm
