Complete individual objects above specified Z height
mechedd
(@mechedd)
Is there a way to add a modifier such that individual objects are completed after a specified layer height? I don't think there is, but want to make sure and see if the community has any ideas on how to accomplish that.
Thank you,
Dan
Posted : 10/09/2022 8:27 pm
It's trivial to cut the top off a part and discard the upper section ...
What are you trying to do?
Posted : 10/09/2022 11:48 pm
mechedd
(@mechedd)
I don't want to discard the tops. "Complete individual objects" is an option in the slicer and I would like to "check the box" about 3/4 of the way up the part. I noticed the tops look better when "Complete individual objects" is turned on, but I can't fit as many parts on the bed due to clearance issues if I use "Complete individual objects" for the whole print. I'm still trying to dial in settings to reduce imperfections and hopefully won't need that functionality. Just a thought and wanted to see if it would improve the quality.
I notice a limited set of print settings can be changed using modifiers. I was originally going to add a modifier box covering the top 25% and turn on "Complete individual objects" but it wasn't an option. Is it possible to switch all print settings starting at different layer heights?
Posted : 11/09/2022 2:46 pm
RE: Complete individual objects above specified Z height
I don't believe you can do that in the slicer currently.  I also do not recall seeing that as a feature request on the Prusa Slicer github either.
Posted : 11/09/2022 7:55 pm
