Colorchange Z Height reversed
Vesh
 Vesh
(@vesh)
im using a colorchange at height 16mm ( 18mm print ), but the printer is asking me to change color at 2mm. whats causing the problem and how do i fix it?
Opublikowany : 08/05/2020 10:00 am
RH_Dreambox
(@rh_dreambox)
RE: Colorchange Z Height reversed
You may have thought a little wrong when you set the height, because the printer stops for color change at the height you specify.
Pull the upper slider down from 18 mm down to 16 mm to get it right.
Opublikowany : 08/05/2020 1:10 pm
Vesh
 Vesh
(@vesh)
but thats exactly what i did. it worked previously too, not its working right anymore. however i flashed firmware again and reset eprom now its workinga gain... weird
Opublikowany : 08/05/2020 9:05 pm
