Carbon-fibers enhanced filaments, Polycarbonates...
nbadjev
(@nbadjev)
Hello guys. I am thinking of buying a prusa i3 mks3.
How well can the prusa print filaments like Carbon-fibers enhanced filaments and polycarbonates?
Do you have any experience? If you use a polycarbonate for a print, can you use pla separately for support purposes?
Thanks
Opublikowany : 14/12/2020 1:55 pm
RE: Carbon-fibers enhanced filaments, Polycarbonates...
Posted by: @nbad
Thanks
It printed CF filaments and PC well.  As far as uring PLA for supports, you would beed and MMu2 and I am not sure that would work.  The filaments require significanly different settings.
Opublikowany : 14/12/2020 2:14 pm
nbadjev
(@nbadjev)
@cwbullet
Do you have any experience with cpe or cpe+ or nylon? Thanks
Indeed the settings would need to be changed for all those different carbon fibers or polycarbonates...
Opublikowany : 14/12/2020 2:51 pm
Nikolai
(@nikolai)
Printing PC works perfectly fine. Just make sure to use an enclosure.
PC with PLA should be difficult. For PC you want very hot environment, high bed temperature. PLA would just melt away under this temps. This applies to any printer.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 14/12/2020 5:46 pm
nbadjev
(@nbadjev)
@nikolai-3
but is it true that the hotend can reach temperature up to 300°C?
Opublikowany : 14/12/2020 9:37 pm
