Can't make PS to fully support an overhanging surface
Husflid
(@husflid)
I am designing a quite complex structure with a small overhang on one side. Somehow I can't make Prusaslicer to fully support this overhang. I made a small test model to simulate the situation and it behaves in the same way:
With support everywhere enabled PS only creates support along the perimeter and not supporting the whole surface. I tried also the other support setttings including paint-on support but I seem get the same result.
What am I missing, and is there a way to force support under the whole overhanging surface?
I attach the 3mf (zipped) of my test object
Attachment removed
Opublikowany : 20/09/2021 8:21 am
Husflid
(@husflid)
Found the solution myself
The tickmark "don't support bridges' was on. Unchecking it makes the support behave as I require.
Opublikowany : 20/09/2021 8:49 am
Yes it does.  That particular question has been answered on the forum hundreds of times already.  Its a pity the forum search sucks.
Opublikowany : 20/09/2021 12:27 pm
