Can someone tell me what causes this on the first layer
Nimitz
(@nimitz)
As you can see from the pic, on the first layer I sometimes get these small rough or blotchy spots.  the object ends up being printed just fine except that on the outside edge it is a little rough where this occurred.  what causes this?
Veröffentlicht : 14/04/2020 7:02 pm
JustMe3D
(@justme3d)
RE: Can someone tell me what causes this on the first layer
The pic is not really good. Looks to me like a first layer Z-value a bit too low, where on the shorter tracks the nozzle pushes the filament more than on the longer tracks. To achieve a very good first layer, I as many others use Jeff Jordan´s first layer calibration method; if spots looking different persist, I´d proceed with Prusa´s bed levelling advice.
Veröffentlicht : 14/04/2020 10:57 pm
Peter M
(@peter-m)
How to see what is good with first layer calibration.
And make better picture.
Veröffentlicht : 15/04/2020 7:09 pm
Nimitz
(@nimitz)
Since I've already done the live Z cal according to the above I decided to do a 2nd print.  as you can see from the pic the first layer looks good although there are issues with the supports layer.  could this be issues with the filament consistency/quality?  I'm using Hatchbox like I have in the past ...
Veröffentlicht : 16/04/2020 11:54 am
Clean your bed with basic dish soap and plenty of HOT water to rinse it away.  You need really good clean bed for those support bottom patterns to stick properly.  I know you will see many many posts all saying the same thing but that's because its true.   Get you bed cleaned properly and the live z dialled in (which it looks like you have now) and you will be surprised at how well things will stick to the smooth sheet.
Veröffentlicht : 16/04/2020 12:22 pm
Nimitz
(@nimitz)
how often do you need to clean the bed.  I did a while ago using dish soap  & hot water but have done about 12 prints since then ...
Veröffentlicht : 16/04/2020 6:00 pm
I probably clean mine every 3-4 weeks, so 15-20 prints on average lol. Then again I’m pretty careful about not touching the bed now. I also don’t mix materials anymore, I use one sheet for pla and another (non Prusa one) for PETG which has a pei sheet like the Prusa one on one side and bare steel on the other, which I use for my occasional ABS prints.
Veröffentlicht : 16/04/2020 7:22 pm
Nimitz
(@nimitz)
thx. its probably time to clean the bed then ...
Veröffentlicht : 16/04/2020 9:26 pm
Dat Concept
(@dat-concept)
I have a different first layer problem, and I do not understand why this happens... Does somebody know? And can they please help me 🙁 this is only one spot. But a lot of times I have a lot of them 🙁
Veröffentlicht : 21/04/2022 9:23 pm
That looks like what you get from a finger print. The oils from your skin cause localised issues. Clean with detergent as mentioned previously. It’s why you don’t touch the bed at all.
Veröffentlicht : 21/04/2022 10:10 pm
Dat Concept
(@dat-concept)
Thank you very much for your help and your reply, I just tested it and you are right this is the issue that caused it! Thank you very much 🙂
Veröffentlicht : 21/04/2022 10:40 pm
