Burn marks
Nino Nobile
(@nino-nobile)
Burn marks
Hi guys, I keep printing my cabinets and from time to time I find burn marks on the top of my prints, the bridges come out well and I have tried filling in support structures. Any advice?
Attachment removed
Opublikowany : 24/09/2019 1:38 pm
1 ludzie polubili
RE: Burn marks
I have had similar burn marks.  Not sure what causes them.
Opublikowany : 24/09/2019 4:34 pm
Bunny Science
(@bunny-science)
RE: Burn marks
I suspect that is old, cooked, plastic residue from your print nozzle or heat block. It is falling onto your print and then getting covered with new extrusion.
Opublikowany : 24/09/2019 5:40 pm
RE: Burn marks
@guy-k2
You gotta love Klingons.
Opublikowany : 24/09/2019 6:02 pm
Nino Nobile
(@nino-nobile)
RE: Burn marks
@guy-k2
That makes a lot of sense, in fact I thought about it at some point, but I looked the other way when I thought about the amount of time it would take me to disassemble the hotend and clean it thoroughly.
Attachment removed
Opublikowany : 25/09/2019 2:10 pm
rmm200
(@rmm200)
RE: Burn marks
Not burned junk from inside the nozzle - stuff falling off the outside. Try a brass brush before you print this one.
If you do want to clean the hot end, use a cleaning filament and a cold pull. No disassembly required.
Opublikowany : 25/09/2019 3:55 pm
1 ludzie polubili
