Bridge Infill
Nicolas
(@nicolasgold)
Bridge Infill
Hi! I want to print a logo in a bottom of a design (style the ORIGINAL PRUSA on the LCD printed piece) but the slicer is always creating this Bridge Infill (blue one) which I don't want to have. How do I cancel it? Thanks!
Respondido : 08/11/2019 10:39 am
RE: Bridge Infill
When you are in Prusa Slicer turn off the Detect bridging option.  Print Settings>Layers and Perimeters - Detect Bridging perimeters.  Its a yellow coded setting though so you need to be in either Advanced or Expert mode to see it.
Although to print like that it probably needs to be detected as bridging.  When I print text like that I have it enabled so if your text isnt coming out correctly its not likely the bridging thats the problem, in this case bridging is a good thing.  If its not a bridge it will want to add support and that is not optimal for something like that.
Respondido : 08/11/2019 12:44 pm
Sembazuru
(@sembazuru)
RE: Bridge Infill
The bottom of the inset lettering on the Prusa printed part looks like bridging to me.
See my (limited) designs on:
Respondido : 08/11/2019 2:02 pm
Nicolas
(@nicolasgold)
RE: Bridge Infill
@neophyl
Hi! Thanks for the replay 🙂 I turned off the Detect Bridging perimeters, but the blue bridge infill still there :/
Respondido : 08/11/2019 2:27 pm
Nicolas
(@nicolasgold)
RE: Bridge Infill
@sembazuru
It is bridge infill... and I dont know how to turn it off, because actually I dont need it...
Respondido : 08/11/2019 2:28 pm
