Bottom layer of prints
Rain426
(@rain426)
Hi all, my bottom layers are nearly perfect, in places the prints are smooth as silk, and others there isn't quite enough squish. Could this be an auto-levelling glitch? Any ideas gratefully received!
Opublikowany : 09/01/2023 11:50 am
RandyM9
(@randym9)
RE: Bottom layer of prints
Are you using 7x7 mesh bed leveling? If not, select that via the LCD menus.
If that doesn’t help, try lowering your Z height just a little. Sometimes a bit more ‘squish’ where it looks good doesn’t hurt anything and improves areas that are a bit thin.
Lastly, there are bed leveling adjustments you can make via the LCD menus for left, right, front, and back, to compensate further.
Try each of the above steps in order and let us know how you make out.
Cheers
Opublikowany : 09/01/2023 4:30 pm
Rain426
(@rain426)
Thanks for the suggestions ☺️ I am already using the 7x7 levelling, but will try the other steps and let you know. Thanks again!
Opublikowany : 09/01/2023 4:32 pm
