"Blobs" on corner
Hello there,
I have printed the following and got these errors on the corner of the print. They are only one side (but both corners), all other sides are very clean. I used PLA 215C and changed retraction to 1.1mm. Other than that I have default settings. Any Idea why this happened?
Thanks!
Best Answer by FoxRun3D:
Look for more information on Z-seam and its placement here:
Napsal : 28/08/2021 7:36 am
is your seam
You can control where it happens, but it will happen.
Napsal : 28/08/2021 9:02 am
1 lidem se líbí
https://help.prusa3d.com/en/article/seam-position_151069/
Napsal : 28/08/2021 10:59 am
1 lidem se líbí
