Basic Stringing Test
I'm trying to stringlessly print this with Hatchbox PLA. The only way I've managed to get a visible reduction in stringing is by turning up retraction length to 4mm, but I'm afraid that would eventually lead to clogs. Any settings advice for this?
Publié : 25/05/2018 11:26 pm
Re: Basic Stringing Test
Goodness - that's terrible for PLA. I recommend you lower your extruder temperature at least 5, maybe 10 degrees. You shouldn't have anywhere near that much retraction on a direct drive like the MK3. For PLA, I run .75mm retraction. Here's a very quick print.. I turned temp from 220 down to 210 half way up the towers, helped a bit more.
Publié : 26/05/2018 12:14 am
RE: Basic Stringing Test
Hi guys,
I got similar issues...
I tweaked the temperature from 215 to 200 deg fpr PLA but it is still not perfect.
Do I have to expect no strings at all ?
Publié : 18/02/2021 9:58 am
