Banding(?) issues in an area of this model
J_Halle
(@j_halle)
Hey guys.
So I have an issue when printing this self watering flower pot where I get about 2cm of banding in the middle of the print.
I don't have this issue at the same hight when printing other models, so I don't think it's anything loose in the printer itself.
Is there a setting that might have done this?
I had Detect Thin Walls and Extra Perimeters If Needed enabled.
Otherwise I followed the modelmakers recommendations:
• Layer Height: .3mm
• Vertical Shells (Perimeters): 3
• Horizontal Shells (Solid Layers): Top – 4, Bottom – 4
• Infill: 10%
• Speed: Top Solid Infill – 15mm/s, Solid infill – 15mm/s
• Prints WITHOUT supports
Hope you have any tips I can try out.
The printer is an i3 MK3S and the material is PLA.
Respondido : 27/04/2020 9:10 am
JustMe3D
(@justme3d)
RE: Banding(?) issues in an area of this model
Whatever the problem is - PLA is the last material I'd use for a flower pot containing water.
Respondido : 27/04/2020 11:49 am
