bad supppports
I've got this file I'm trying to print that's about 80 mm wide and need support. when prusa slicer makes them it only puts them, on the outer edge resulting in the bottom layers and lower infill being very weak and roopy in most places. Is there anything I can do about this in the slicer settings, or even make customer supports?
Best Answer by 3Delight:
Have you tried deselecting "Don't support bridges" under Print Settings -> Support Material?
This topic was modified 6 years temu by layden_blackwell
Opublikowany : 24/08/2020 9:33 pm
RE: bad supppports
Opublikowany : 24/08/2020 9:49 pm
Topic starter
answered:
RE: bad supppports
@3delight
... you know I saw that and thought nothing of it but now I might try it, thanks.
Opublikowany : 24/08/2020 9:58 pm
RE: bad supppports
Let us all know if it works!
Opublikowany : 24/08/2020 10:09 pm
Topic starter
answered:
RE: bad suppports
UPDATE: sorry I was away for a few days but, when I returned I found a near perfect print Thanks to @3delight
Opublikowany : 26/08/2020 4:17 pm
