Baby Yoda won't finish correctly
Frank_The_Rock
(@frank_the_rock)
I try to print this nice baby Yoda By Christopher frieze.  I set it at 0.1 detail with prusament filament Pla.  It print all the way nice until the last top part witch are small perimeter.   The first was a bit empty so I add a modifier to change the density and type of infill for the top of the head. It gave me #2 .  Then I set all speed to 25 and tried it with just the top part mark Slow  With look perfect.   Then I tried to print this again with all modifications and I get #3 witch is not perfect .
What should I test or change to have a flawless Yoda ?   I was thinking bumping the bed temp to 70 so I printed a test cap that was not good, actually look like the 3.  So do I slow the head even more so the cooling work better?
All idea is welcome!  Thanks
Veröffentlicht : 13/12/2019 1:44 am
