Baby Yoda won't finish correctly
I try to print this nice baby Yoda By Christopher frieze. I set it at 0.1 detail with prusament filament Pla. It print all the way nice until the last top part witch are small perimeter. The first was a bit empty so I add a modifier to change the density and type of infill for the top of the head. It gave me #2 . Then I set all speed to 25 and tried it with just the top part mark Slow With look perfect. Then I tried to print this again with all modifications and I get #3 witch is not perfect .
What should I test or change to have a flawless Yoda ? I was thinking bumping the bed temp to 70 so I printed a test cap that was not good, actually look like the 3. So do I slow the head even more so the cooling work better?
All idea is welcome! Thanks
