Any Ideas?
Lonman29
(@lonman29)
Any Ideas?
As you can see I’m having a bit of an issue with layer shifting. I’ve recalibrated Z more times than I care to admit and still the same issue. Noob at all this… Any suggestions would be greatly appreciated 🙏🏽
Opublikowany : 30/12/2021 9:20 am
RE: Any Ideas?
Check your grub screws on the motors / gears and your first later looks a bit too low.
Opublikowany : 30/12/2021 12:20 pm
RE: Any Ideas?
* Pulley screws on X motor not properly tightened. One has to be tightened against the flat side of the motor shaft!
* Belt not correctly tightened. Use this tension meter to get it right: https://www.prusaprinters.org/prints/46639
* X carriage over-squeezed. Loosen the back plate on the X carriage axis.
* Nozzle hit an obstacle. Some patterns such as grid have lines that cross within one layer. This can lead to little pile-ups at the intersection points, in particular if you have slight overextrusion, which in turn can lead to the nozzle catching at those pile-ups. See https://help.prusa3d.com/en/article/infill-patterns_177130/
* Zip ties on the wire bundle on the back of the extruder not properly positioned, so they or the cables hit the model.
Opublikowany : 30/12/2021 2:30 pm
