Z height inconsistency
Kurosound
(@kurosound)
Hello everybody, I'm new in this forum. I would like to thanks the Prusa team for the great Job. THANKS!!!!!!!! <3
I bought the Prusa i3 mk3 a few months ago. Since then everything works great and I had a great 3d print experience.
A couple of weeks ago I bought the carbon filament and the hardened nozzle. I printed some very wonderful work with that filament.
A few days later I decided to unload the carbon filament and load the pla filament to test the hardened nozzle behavior with the common filament.
When I launch the print the nozzle crashed on the bed surface trying to print at Z=0.
My PEI sheet was ruined and I switched the hardened nozzle with the brass original one and I did all the calibration again.
It was very hard to find a good setting because the right side of the bed was higher than the left side. But after many tests and after I used the bed compensation settings I reached a good first layer setting.
After that, I restarted to print my stuff for a couple of days. But without any reason, the printer after the bed leveling procedure starts to print without increase the z height so the nozzle crash on the PEI bed with damages and discouragement.
I tryed to downgrade the firmware to the previous version but nothing.
I tried to print gcode file from the original prusa SD card with no results.
I can't understand what's the problem.
I hope someone in the community can help me.
Thanks to anybody for any help.
Bruno
Postato : 04/11/2018 11:45 pm
AntiklesyS
(@antiklesys)
Re: Z height inconsistency
Have you checked if your FINDA Probe is working properly?
Postato : 05/11/2018 8:53 pm
Kurosound
(@kurosound)
I installed bed visualizer on octoprint and the results should be ok, but when I start the print the i3 tries to print at z=0 damaging the bed
Postato : 05/11/2018 10:24 pm
Kurosound
(@kurosound)
in the image below pinda finds the right bed side lower than the left.
I assume the origin is in the left down side of the bed.
During the first layer calibration the right side of the bed is higher respect the left side; in fact the printed on the right is thinner than the left side. How is possible the PINDA reads the opposite?
I'm very confused: everything was perfect until few days ago and now my printer is useless. I suspect there is no way to ship the printer back for the fixing.
Postato : 05/11/2018 11:36 pm
Kurosound
(@kurosound)
I solved everything by a factory reset and a new calibration.
Thanks a lot to the live chat guys!!!!!!!!!!!!!!!!!!!!!!!
Postato : 08/11/2018 12:15 pm
