Z Calibration issues. Machine thinks z zero is the upward position of machine instead of the bed.
Hello all,
I need some help with my Prusa MK3. You see when I do my x,y, z calibration, the x and y calibrate out fine but when it does the z axis it goes to the highest point of the machine and booms out. The calibration at this point fails and it tells me to check the z connections and rerun. At this point if I manually try to lower the z axis it thinks it is near the bottom rather than the top, so it will not manually go down. It thinks it is at z zero or thereabouts, in the upward position.
Are my z motors malfunctioning or is the error in the person, Me!
Any and all responses would be greatly appreciated.
Thank you, Craig
Veröffentlicht : 21/09/2024 10:39 pm
