Z-axis "stuttering" and moving unevenly
kahoover
(@kahoover)
Was working perfectly well for a number of prints, then I powered it back up to print something and the Z axis was out of calibration. I tried recalibrating and noticed that the Z-axis was sort of "dancing" -- stuttering on the first slow motion, then catching up to relevel the axis (sort of) but still losing ground against the other side. I swapped the stepper connections and the problem is only on the left-side stepper. Also, I can move the left-side stepper lead screw with my fingers and slight force which I can't with the right. Just got this printer last week -- am really disappointed its failed this fast.
Respondido : 14/03/2019 9:32 pm
vintagepc
(@vintagepc)
Miembro
Re: Z-axis "stuttering" and moving unevenly
Check the conical dust caps you had to thread all the way down the Z screws. Make sure they are not binding against the motors.
Respondido : 14/03/2019 9:36 pm
kahoover
(@kahoover)
Sorry, that was the first thing I did. They are backed off about 1 cm right now, just so I can be sure they aren't binding. Second thing was to release and re-tighten the trapezoid nuts on the threaded nuts and to release and re-tighten the top caps (I actually ran them with no tension one round to make sure they weren't binding. Given that I can move the left axis when its energized, I suspect that there is a shot coil in the stepper but I'd be thrilled to find it isn't that.
Respondido : 14/03/2019 9:47 pm
Also check the top brackets ... debris or even a misprint in the cup at the top can cause stumbles. Rare, but possible.
Also - a bad bearing on that side can also be the culprit.
Respondido : 15/03/2019 1:14 am
vintagepc
(@vintagepc)
Miembro
If you've checked all these things, your best bet is then probably live chat in the prusa store. If it is a bad motor (or other part) they'll get you sorted.
Respondido : 15/03/2019 1:35 am
kahoover
(@kahoover)
Answer was: blown coil in the left Z stepper. red-blue infinity, black-green 8.2 ohms. Prusa sending a replacement.
Respondido : 20/03/2019 5:25 pm
Let us know how this works out. A motor with a bad coil won't (in theory can't) rotate / step from one position to the next. So it'd never actually move the axis up or down. A broken wire or connector that is intermittent is much more likely.
Respondido : 20/03/2019 10:48 pm
