Y motor failure?
sonnydays15
(@sonnydays15)
Y motor failure?
I've been getting a lot y-axis stepoffs and fails. I ran XYZ calibration, which went fine, failures still happened. Then I did an autohome, fine. Then ran a belttest and the y-motor stopped halfway through the belt test. I can then run an autohome and run it again, but it still continues to fail.
Do I need to just replace the motor, or is there an easier solution I'm missing?
Thanks!
Belt test failure
Publié : 24/07/2022 10:30 pm
