Y axis not calibrating properly.
Flatbutt
(@flatbutt)
I have a month or so old MKS3.  Recently it stopped printing complaining of a bad y belt tension.  My unit has the adjustable belt.  I went through the online instructions and found that no matter how I adjusted it I kept get readings where the last tension was between 255 and 279.  And yet if failed my calibration every time.
What should I try next?
Postato : 28/03/2021 8:37 pm
Belhaven Math
(@belhaven-math)
RE: Y axis not calibrating properly.
Funny, the exact same thing has happened to me as well. I am wondering if it is a bug with the newest firmware update. My printer was running fine before the update. I am going to try to flash it again with the older firmware and see if that fixes it.
Postato : 28/03/2021 9:28 pm
Dan Rogers
(@dan-rogers)
download and print the belt tension tool from Prusa.  It's a PETG only print.  The #'s from the sensors can be misleading.
The belt should thrum when you pluck it.  It should make a low tone.  If it is too tight, calibration will complain that it can't get the full length of the travel.
Do a rough adjustment so you can print the belt gauge, and then use that.
Postato : 29/03/2021 6:45 pm
1 persone hanno apprezzato
Belhaven Math
(@belhaven-math)
Yeah... the firmware didn't help.
Postato : 29/03/2021 6:54 pm
