Y Axis error
Ravensrook
(@ravensrook)
Y Axis error
I came back from a vacation for 2 weeks and turned my printer back on, and I am having trouble getting the Y axis to properly home. I've re-seated the belt and made sure it isn't too tight or too loose, but no matter the changes I make I keep getting this error. Not sure what else I need to try or fix.
Posted : 02/10/2022 7:15 pm
RE: Y Axis error
Have you already read this post: https://help.prusa3d.com/article/check-axis-length-x-y-z-mk3-s_134223
Try to deactivate crash detection in normal mode and also try stealth mode.
guides/rods are lubricated?
wbr,
Karl
Posted : 02/10/2022 7:59 pm
Ravensrook
(@ravensrook)
RE: Y Axis error
Yes, I've disabled crash detection, I was having issues with that when I first assembled the printer. And the rods are still pretty well lubed.
Posted : 02/10/2022 9:15 pm
Zoltan
(@zoltan-d-2)
Member Moderator
RE: Y Axis error
@ravensrook
what is the current status?
Posted : 05/11/2022 7:50 am
