Y axis chrashes
emapola
(@emapola)
Mitglied
Y axis chrashes
On my MK3 (kit) printer I noticed several problems with the y axis.
Sometimes it crashes.
I have tried various firmware versions over time, modified y-axis belt mounting supports, custom slicer profiles (chris), lubricated rods with ptfe, increased belt tension.
Measured with the gauge the distance of the belt of the y axis and adjusted to be equidistant from the frame.
I have no more ideas.
Any suggestions?
https://photos.app.goo.gl/Dhht175VUfYQd3Tm9
https://photos.app.goo.gl/Ypim7Ff6AurhK66x8
https://photos.app.goo.gl/h6Nv9pR4H8J9ExyG9
https://photos.app.goo.gl/843Bsbty9hGhhdzr7
https://photos.app.goo.gl/z7bDaKVt2ZSJXqbW7
https://photos.app.goo.gl/CsghC2Ht9s8seYkF8
https://photos.app.goo.gl/KXnrcmygdYtqQB3F8
https://photos.app.goo.gl/dEirEzN34VQBRyLLA
https://photos.app.goo.gl/B7mGSScKBKyGmE5VA
https://photos.app.goo.gl/85RPrkVGGT18RLBN9
https://photos.app.goo.gl/7s8Q1qVCrSpfHH737
https://photos.app.goo.gl/FF4dCfFZEYhNg41BA
https://photos.app.goo.gl/kEBjWgfoACNVATFx6
https://photos.app.goo.gl/DrkqEP3va9efunuL7
Veröffentlicht : 04/07/2018 1:19 pm
RH_Dreambox
(@rh_dreambox)
Re: Y axis chrashes
Check that the tire straps at the Y-axis front and back are seated correctly and do not collide with the bed frame (the frog).
If the u-bolts on the frog are too tight, the bed frame can collide with the mid frame.
Check this by manually moving the bed back and forth (depress the bed carefully during the test).
Veröffentlicht : 04/07/2018 6:10 pm
