XYZ Calibration failure
Sean
 Sean
(@sean-6)
My part shifted on the build plate and I got a blob of doom on my hot end. While I was trying to melt the blob off my thermistor tore so I took the entire extruder apart and replaced the thermistor.
So now I have everything back together again but when I run the xyz calibration the z axis moves to the top of the frame and then it asks me if I have the steel sheet on and when I say no it immediately reports back axes failure.
when I click the dial control to return to the main screen the status at the bottom of that screen says end stops hit.
I have manually moved the axis its moving nice and easy.
I have a few hundred hours on this printer and up to know I have had no issues but I am stumped and I don't know what the issue is now. The extruder is assembled correctly.
Does anyone have any suggestions?
Firmware is 3.3.1-845
Veröffentlicht : 20/08/2018 3:14 am
Sean
 Sean
(@sean-6)
Re: XYZ Calibration failure
Solved my own issue. Broken black wire on the pinda probe. little solder n some shrink tube and we are back up n running.
Ordered some spare parts from Prusa for future.
Veröffentlicht : 20/08/2018 9:16 pm
