XYZ Calibration faild. Check the axes and run agian!
Hello,
I have a problem with XYZ calibration. Printer MK3 worked very well until today's firmware update. I have run new calibration over the wizard and the process finished at step where is checked Z axe on the bottom of track and should start X and Y calibration. I have run XYZ calibration in wizard mode and also separately. I restarted printer and also reset the calibration. PINDA probe working well and seems to be align correctly on all axes. It is about 1mm above the surface and stops on correct position if I run Auto Home.
Any idea what to try?
Publié : 10/06/2019 5:20 pm
Topic starter
answered:
RE: XYZ Calibration faild. Check the axes and run agian!
My fault. Wrong version of firmware. Instead of MK3 it was MK3S.
Publié : 10/06/2019 5:53 pm
