X, Y, Z axis when print paused.
I am invisible
(@i-am-invisible)
I paused my 3d print and am wondering what the difference in the X, Y, and Z axis is when the print is paused. I am using the Prusa i3 mk3 at my local library so I can't go back there at the moment, but it was closing so I had to pause and turn off the printer. I did get the Z axis when it paused though, it said 37.4. I am now trying to find out what the default pausing position is on the Prusa i3 mk3 so i can calculate an approximate position to continue my part in the gcode. Does anybody know the default position the Prusa goes to when the print is paused?
Opublikowany : 25/03/2023 11:21 pm
Don't bother, it will almost certainly have come loose as the printer cooled.
Instead cut the model at that layer and print just the upper part seperately then break out the glue.
Opublikowany : 26/03/2023 3:53 am
