X, Y, Z axis when print paused.
I paused my 3d print and am wondering what the difference in the X, Y, and Z axis is when the print is paused. I am using the Prusa i3 mk3 at my local library so I can't go back there at the moment, but it was closing so I had to pause and turn off the printer. I did get the Z axis when it paused though, it said 37.4. I am now trying to find out what the default pausing position is on the Prusa i3 mk3 so i can calculate an approximate position to continue my part in the gcode. Does anybody know the default position the Prusa goes to when the print is paused?
Don't bother, it will almost certainly have come loose as the printer cooled.
Instead cut the model at that layer and print just the upper part seperately then break out the glue.
