X Axis motor problem
Rob Carr
(@rob-carr)
Postato : 09/06/2021 4:45 pm
Baklin
(@baklin)
RE: X Axis motor problem
I would think this is a broken motor, broken cable or loose connector.
What happens when you switch the X and Y connectors on the Einsy board? If the problems stays with the same motor you need a new motor or try to fix that cable if you can find a problem there.
If the problems moves to the Y axis you have a problem with the Einsy board or the firmware.
Postato : 09/06/2021 4:53 pm
OK.  What happens if you temporarily switch the connectors with one of the other steppers?  Test both.
Does the problem move with the motor, or stay with the connection/socket?
Postato : 09/06/2021 4:54 pm
Rob Carr
(@rob-carr-2)
Hi all
Hopefully someone can help me. I have had my Mk3s for sometime and earlier this year I fitted a Raspberry Pi and Octoprint to it. Everything has worked fine until the fan I fitted to cool the Raspberry Pi became noisy.
The Raspberry Pi was fitted below the Einsy board using a new printed housing that I found on this site and was wired into the Einsy board. I took the Pi off including the wiring and when I powered back up the printer, everything seemed fine. I then tried to print a model and the X axis failed to home, it just moved a little and made clicky noises.
At first I thought it might be something to do with the belts but I couldn't find anything amiss. I then took the X axis motor  off and you can see the problem in the video. The motor is no longer working as it should. I have checked the plug and the wiring but can't see anything wrong.
Any thoughts from anyone would be much appreciated before I fit a new motor and Einsy board.
Postato : 09/06/2021 5:00 pm
Baklin
(@baklin)
I see waiting for you posts to be approved mixed things up a bit.
Try switching the motors first and see what happens.
Postato : 09/06/2021 5:25 pm
Rob Carr
(@rob-carr-2)
@baklin
Thanks for the prompt replies, you were faster at replying than I was with my posting 😀 For some reason I couldn't add text to the video post.
I will swap the plugs over on the motors as suggested and report back tomorrow.
Thanks again.
Postato : 09/06/2021 9:25 pm
Rob Carr
(@rob-carr-2)
@baklin
Morning
I have swapped X and Y Axis connectors and the problem is transferred to the Y axis so the X axis motor is fine.
Is there a driver on the board that can be swapped or do I need to replace the whole board?
Postato : 10/06/2021 9:21 am
Baklin
(@baklin)
If that motor is fine, you probably damaged the board some how. I would make sure there is nothing left of that raspi and fan that could some how short something out.
After that I would try reflashing the firmware, just in case. That takes little time and is the cheapest fix.
If that doesn't help I'm afraid you need a new board. I don't thing it will be easy to fix an Einsy board. But if you can see a burned part maybe you can identify it and replace it (let some one replace it.)
Postato : 10/06/2021 10:00 am
Rob Carr
(@rob-carr-2)
@baklin
Ok thanks for confirming the diagnoses. I do have a replacement board (printer is a business machine and needs to be up and running) so I will check the existing board for burnt patches and then just replace the whole thing.
Thanks
Rob
Postato : 10/06/2021 11:04 am
