X axis layer shifting
dloyer
(@dloyer)
Having problems with layer shifting on the x-axis.
The x-axis seems to shift for a few layers then shift back.  Seems to be getting worse.
Tried taking apart the head and adjusting the belt tension.  No avail.  Tried tightening all of the screws I can reach.  Also tried recalibrating.
Only thing that seems to help is to print VERY slowly.
No problem on the y-axis.  Got some prusamint petg and printed the belt calibration tool.  Looks ok.  Pictures attached.
Driving me crazy.  Any suggestions would be appreciated.
Best
-Doug
Respondido : 20/01/2022 9:01 pm
Bob
 Bob
(@bob-2)
RE: X axis layer shifting
Check your connection to the Rambo board, it may be a bit loose.  I had an Ender 3 with a bad cable between the board and the X axis servo, once I replaced it the problem was solved.  Prusa uses higher quality parts, but the plug may be a little loose.
Cheers
-Bob
Respondido : 20/01/2022 11:23 pm
dloyer
(@dloyer)
Thanks Bob.  Worth a try.  I tried removing and reseating the connector for the x axis motor.  No joy.
Super strange.
Best
-Doug
Respondido : 21/01/2022 4:14 pm
Zoltan
(@zoltan)
Miembro Moderator
How about a losen pulley screw? Or temperature-profile issue?
Is it happening allways?
Respondido : 21/01/2022 7:07 pm
dloyer
(@dloyer)
Hi Zoltan,
Yeah. It does seem to happen consistently.  Often in the same place if I print the same file.
What I cant figure out is why it shifts back.  If it was missing steps, I would think it would just get further and further off.
Also happens in stealth mode, so it cant be crashing and re homing.
I will check for a loose pulleys.
-Doug
Respondido : 22/01/2022 2:38 am
dloyer
(@dloyer)
Solved!
Tightened the screws that hold the x axis stepper motor shaft to the belt.
Also reduced the max acceleration in the slicer, but I think the tightening the screws did the trick.  Printing a old file to confirm.
Thank you for all of the suggestions here.
-Doug
Respondido : 23/01/2022 3:26 am
Zoltan
(@zoltan)
Miembro Moderator
Great,
I amm happy it helped. Enjoy !!!
Respondido : 23/01/2022 11:07 am
