X-axis (bed) is not moving..
ctm555
(@ctm555)
Hi!
My X-axis (bed) is not moving after a lightning strike a week ago. Everything else is fine. Printing works, but only 2D 🙂 No error codes, self-test fails of course.
Tried this:
1 - Updated to latest FW...
2 - Swapped X-cable with Y-cable on the controller board. Now the bed is moving, but the head (Y-axis) is not -> It has to be the controller board , right?
3 - Measured both +24V from PSU - OK.
4 - Checked all fuses - OK.
Should I order a new controller board, or do anyone know if there is something else I should try before?
Best Regards, Viktor
Opublikowany : 27/07/2024 5:08 pm
RE: X-axis (bed) is not moving..
tell us, where you are
somebody near you may have done a mk4, or mk3.9 upgrade, and have a spar controller...
Opublikowany : 27/07/2024 6:58 pm
ctm555
(@ctm555)
I'm in Sweden.
Opublikowany : 27/07/2024 7:08 pm
ctm555
(@ctm555)
Removed the board and it's visibly damaged. Ordered a new one.
Opublikowany : 28/07/2024 8:21 am
