X and Y calibration
Ron Hunt
(@ron-hunt)
X and Y calibration
So.. I am printing something that requires tight tolerances and have noticed that the MK3 I bought for work is not quite good enough. At home I can print a 20x20 cal cube and its almost perfect. Here I am about .3% off. The issue is we are printing something that needs to be 200mm exactly and it is coming in at 199.3 at Y while X is right at 200mm.
I scaled Y axis by 0.3% and it is coming out correct.
So on my CR 10 or Tronxy I would adjust Steps/mm to calibrate. My question is: Does the XYZ calibration in the firmware do this? I’m assuming “yes” since it knows exact theoretical position by the 4 magnets. I assume I must have just gotten a slightly poor calibration?
I will likely retry the XYZ cal and see if things improve.
Thanks in advance,
Ron
Napsal : 04/07/2018 11:33 pm
Gato
 Gato
(@gato)
Re: X and Y calibration
Steps calibration should be spot on. You can verify (and correct if needed) using this https://mattshub.com/2017/04/19/extruder-calibration/amp/
Napsal : 05/07/2018 5:29 am
OurAngryBadger
(@ourangrybadger)
He's asking about XYZ calibration not extruder calibration
Napsal : 26/10/2018 2:26 am
