Will PrusaPrint work with an external raspberry pi on a Prusa i3 MK3
Just hoping to get end of filament working. When I print from OctoPrint, the Prusa spots end-of-filament (albeit, often falsely), but OctoPrint ends up with a communication reset & loses the print.
Respondido : 13/10/2018 8:01 pm
Re: Will PrusaPrint work with an external raspberry pi on a Prusa i3 MK3
I have been running my MK3 through Octopl for several months now and have experienced several false out of filament stoppages. Each time, the print has resumed correctly after I unloaded/reloaded the filament.
So, no idea why you have a problem, but now you know that Octopi worked correctly, at least in my system.
Respondido : 19/11/2018 12:40 am
it does work usb. ive had plenty of false errors with or without using pi.
but if you can, next time you get a false stop. try hitting "preheat" as soon as possible. it might get saved.
Respondido : 19/11/2018 3:04 am
