will not print after recalibration.
Spence
(@spence)
I have a MK3S+ that I bought in 2021 and have been using with no issues at all for over a year and a half. I started having some adhesion issues so reran the calibration after trying to adjust the bed temp. Now I can not get anything to print at all. First layer calibration works perfectly, self-tests all pass, XYZ calibration passes. I go to do a print and the PLA sticks and balls up on the nozzle, nothing sticks to the bed.. I replaced the nozzle thinking it was damaged and it was scratched and chipped. I've ran first layer calibration at least 20 times and it's set perfectly, I even calipered the test filament and it comes out to .21mm layer height for the print and sticks to the bed extremely well. Temps for the calibration and test prints are 215C on the hotend and 60C on the bed, the calibration sticks , the test print doesn't. I'm completely lost on what to try next. Any help you can provide will be greatly appreciated. Thanks
Postato : 30/11/2022 3:42 pm
RE: will not print after recalibration.
Have you done a live z adjustment since you calibrated it ?  Iirc it resets that to zero so you have to do it again. Use the Jeff Jordan method after the initial run through of the built in one.
Postato : 30/11/2022 4:04 pm
Have you tried cleaning the sheet thoroughly with hot water and additive-free dish washing soap?
Postato : 30/11/2022 5:00 pm
Spence
(@spence)
This is fixed, ended up my extrusion multiplier was resetting for some reason. I had to uninstall and reinstall my Slicer to fix the issue. thanks for the help
Postato : 05/12/2022 8:27 pm
