Which Filament Designation to Use in PrusaSlicer?
hotdogx
(@hotdogx)
I just installed the latest PrusaSlicer software on my computer.  Now I want to create G code so I can print from an STL file and I'll be using Hatchbox PLA filament.  PrusaSlicer doesn't list Hatchbox on their filament list, so which one would be closest to Hatchbox?
Posted : 10/01/2020 11:07 pm
RE: Which Filament Designation to Use in PrusaSlicer?
I would use Generic PLA,
I would reduce the retraction to 0.4mm
and if using a textured build plate I would scrub the build plate with Hot water and Dish soap, then I would rinse with Hot Water and immediately Dry with Clean paper towel I would handle the build plate by it's edges to prevent contamination, before printing on it...
and I would set the heatbed temperature to 70C for all layers
I mostly use un named filament so tend to use the Generic profiles.
I don't use additives  to try and improve adhesion for PLA.
for PETG and TPU/TPE, I use adhesion reducers, Windex, or Talc, or Finger grease,
For health reasons I do not use ABS or ASA
these items are printed in  Generic PLA, directly onto textured build plate and they stuck well, even though they have negligible surface contact
Posted : 11/01/2020 1:06 am
rmm200
(@rmm200)
Take note that those profiles give you a starting point.
As you get experienced with a filament, you will become familiar with it's idiosyncrasies.
Save that as a filament specific profile. I have one called My PLA - Hot, for example.
Some PLA likes 220 - some like 250.
Posted : 11/01/2020 2:15 am
hotdogx
(@hotdogx)
Thanks everyone for the helpful information!
Posted : 13/01/2020 4:51 am
