what am I missing. installed 0.6 mm nozzel
m00k3y
(@m00k3y)
print not sticking
I installed a 0.6 mm nozzle.   changed the setting for the nozzle on the printer.   MK3S+
In the gcode I changed the nozzle to 0.6.
Hopefully someone can point me to what I am missing.   The filiment coming out is much thinner than the 0.4 mm nozzle.  i did check it, the 0.6 nozzle is bigger than the original one.
When I do the first level calibration, no matter what I do,  it does not change the thickness/flatness as it prints.
frustrated...
Publié : 11/09/2022 2:20 am
m00k3y
(@m00k3y)
RE: what am I missing. installed 0.6 mm nozzel
I ran the calibration from the beginning again,  and I had to adjust the z access a lot more than I anticipated.    Got it working.
In case anyone comes along trying to do the same thing.
I set the nozzle size to 0.6 on the printer and also in the gcode I am using.
My suggestion - after the calibration,  print the Prusa test pattern and use that to Live Adjust Z to get  Z dialed in.
1) the border of that print will let you know when you are getting close.  Once it lays out a clear border, that sticks all the way around.   you are close.
2)  once you are that close, when its printing the rectangle that will say prusa,  adjust the z approx 1/3  of the way and 2/3 of the way through the rectangle.
This allowed me to get it dialed in quickly
Publié : 11/09/2022 5:18 am
Is this something you're seeing in actual prints or just the first layer calibration? Try to print a calibration strip like this https://www.prusaprinters.org/prints/105404   instead of using the inbuilt calibration routine.
Not sure what that means. No need to change gcode. But you need to run the Prusaslicer configuration assistant from the Configuration menu again and add the Mk3S+ 0.6 mm printer profile, which will configure everything correctly for you.
Publié : 11/09/2022 11:56 am
Membre
First, read:
One last setting you will want to do:
  • In the menu on the MK3S:  Settings: HW setup: Nozzle d.
Publié : 11/09/2022 1:23 pm
