RE: Wall not filling as a solid
More perimeters when slicing. Use the preview view to see what the inside and outside look like.
Napsal : 19/01/2021 1:38 am
Unfortunately if walls are too thin to have infill and aren't a multiple of the nozzle diameter (or a very small amount bigger than that), the slicer can only accurately get that thickness by leaving a gap. Making it a little thicker or a little thinner will usually sort this out.
The only other solution is a different size nozzle.
Napsal : 08/02/2021 11:22 pm
It should be trying to use gapfill. Do you have gapfill enabled ?
Napsal : 09/02/2021 6:07 am
Topic starter
answered:
Thanks Neophyl, I had gap fill off thinking it would eliminate unnecessary movements but I didn't take into account this. Looks like it should fill the gap now I'll just have to test it.
Napsal : 09/02/2021 2:17 pm
