Unwanted filament changes
ScottM
(@scottm-2)
I am using Slicer 2.3.0 and firmware 3.9.3 on my MK3S. I keep having a problem where the printer will stop printing and beep until I "change the filament". Of course, I don't really change the filament, because it doesn't need changing. I'm beginning to suspect a hardware problem. Has anyone else had this problem?
Napsal : 08/02/2021 5:22 pm
RE: Unwanted filament changes
This sounds like a filament sensor problem.
Try disabling the sensor (in Settings) for a couple of prints, if the problem doesn't recur you know the filament sensor needs calibration.
Napsal : 08/02/2021 6:44 pm
ScottM
(@scottm-2)
I'll give it a try. Thanks.
Napsal : 08/02/2021 6:52 pm
ScottM
(@scottm-2)
I disabled the filament sensor and the prints are coming out now without asking for filament changes. I guess I need to fix the sensor issue.
Napsal : 09/02/2021 8:53 pm
@scottm-2
Diagnosing the problem is half the job. Well done, and good luck with the fix.
Napsal : 10/02/2021 1:14 am
